Gearing
Old Jan 28, 2011 | 01:04 AM
01 beast's Avatar
Default Gearing
Had the truck up in the air the other day, and while i was there I got curious about my gearing. So marked drive shaft, and tire. I had one guy hold one tire, and made sure i was fully engaged between drive shaft and rotating tire. anyway 2 rotations of drive shaft gave me on rotation of tire. That seemed rather strange to me.
the diffs have been re sealed and the tag on the rear is turned backwards when it was put back on
Old Jan 28, 2011 | 06:01 AM
oldgrey90's Avatar
you have to turn the tires at the same time. just unbolt the the tag and look it's not going to make the cover leak.
Old Jan 28, 2011 | 10:13 AM
01quadcab's Avatar
whats your tires size and rpm's at 65?
Old Jan 28, 2011 | 06:01 PM
navy_welder's Avatar
On a 01 it has a tag in the glovebox that tells you everything in the powertrain
Old Jan 28, 2011 | 07:34 PM
turbo20psi's Avatar
Auto or stick?
Old Jan 28, 2011 | 10:01 PM
01 beast's Avatar
Default ok
could not make it out real well but heres what i got
m60/2 front
3.5 3.55 could not see which one
m70/26
Its an Auto
and I forgot to look at rpms in relation to speed on the way to work
Old Jan 28, 2011 | 11:33 PM
heavy hauler's Avatar
Sounds like you got 3.55 gears and 60 front axle and 70 rear axle. It should be turning about 1600 at 60 mph or somewhere close to that.
Old Jan 29, 2011 | 01:55 AM
Cody Cummins's Avatar
my 98.5 has 3.55 gears as well, if you wanna know for sure, call the dealership up and give them the vin number and they will tell you exactly whatcha got!
Old Jan 31, 2011 | 03:22 PM
chadcycle 2500's Avatar
I have 4.10 in mine, 1900rpm@ 60 mph,265/75r16 tires,Need more overdrive!!
Old Jan 31, 2011 | 03:40 PM
01 beast's Avatar
I have yet to have my spedo recalibrated for my 37 inch tires, but I was doing 70 and rpms were around 1800 to 1900. But I'm thinking I was actually doing about 75.
