1997 CTD Problem
Old Nov 26, 2007 | 12:59 AM
pngmotoman's Avatar
Default 1997 CTD Problem
well i havea friend that has been having all sorts of problems with his truck. he has just changed the vp44 the lift pump and the injectors. but now he has amiss at idle and it is hard to start (you have to give it gas to start) now he did put bigger injectors into it so could he be needing more gas?? if so is there a way to turn up the fuel pump?? Or could it be something else?? ohh yah he had a shop do the pump and they say it is timed correct.
Old Nov 26, 2007 | 01:09 AM
Uncle Bubba's Avatar
Got a mix up here. 98.5 - 99 was the first year for VP44's unless this is a transplant motor.
Old Nov 26, 2007 | 05:01 AM
Benjamin's Avatar
Bombardier
with either pump it sounds like you got an air leak before the pump ....
Old Nov 26, 2007 | 05:09 AM
LOGANSTANFORTH's Avatar
only way to get more fueling is through electronics IF it is a 24 valve.......but IF its a 97, its a 12 valve IF the engine is factory.......could be air or the pump on its way out again, check all the fittings on the fuel system to make sure they are tight.....also scan the truck for any codes it might have.....OH and i wouldnt give it any gas maybe diesel though......
Old Nov 26, 2007 | 05:22 AM
onewhl750's Avatar
Depends on what type of truck. Is it a 97 12V or a later year 24V? I would check all the fuel connections for the injectors and make sure they are tight, you might have air in them as well. If they are all tight, then you can try bleeding the fuel injection system. Does it smooth out when the motor warms up? Does it do it if he plugs it in?
Old Nov 26, 2007 | 10:23 AM
pngmotoman's Avatar
ok i know it is a 97 12v and he said it was a vp44 but he is prob wrong. so what pump is it?? once he gets it above idle it smooths out pretty good
Old Nov 26, 2007 | 10:28 AM
Benjamin's Avatar
Bombardier
it's a P7100 (the GOD of all pumps) more than likely there is a leak in the fuel return line that is allowing air to get into the system when shutdown. you can either replace all the old crusty 10 year old rubber line or you can replace it section by section until the problem is gone. i'd go ahead and install a volcan big line kit if i was having to do it.....
Old Nov 26, 2007 | 10:59 AM
pngmotoman's Avatar
ok i'll let him know that. now does he need to get a fuel plate for it since he put bigger injectors in it?? he aparently put stage 2's in.
Old Nov 26, 2007 | 11:07 AM
onewhl750's Avatar
Not necessarily, but a plate is nice to have. He may have to adjust his idle and that may help his idle issue but I agree that is sounds like he has some bad fuel line somewhere in the return.
Old Nov 30, 2007 | 10:35 AM
pngmotoman's Avatar
man he just keeps having problems now he found out that his turbo is bad. so anyone know how much a turbo for him would be or what a good aftermarket one is that will still spull good.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
signoremint
13
Oct 21, 2014 07:21 PM
stoppie
Oct 8, 2014 07:13 AM
