replacement seat bottom cover
Old Jan 27, 2011 | 08:16 PM
njneer1's Avatar
Default replacement seat bottom cover
Just picked up a 98 2500 24V with 5spd............need a replacement lower cover for the drivers seat.....can you still get it from the dealer ? any aftermarket supplier ??
Old Jan 27, 2011 | 10:02 PM
RAW's Avatar
RAW
Does it just have the usual tear on the outside top? An upholstery shop could sew it up, I was able to get it done to mine.
Old Jan 28, 2011 | 08:42 PM
JLWelding's Avatar
Has anybody tryed swapping the passanger bottom set? I dont see why it wont work.
Old Jan 28, 2011 | 09:25 PM
RAW's Avatar
RAW
I think they would be different. The inside would be straight cut, and the outside would has a different pattern for the seat tilt.
Old Jan 28, 2011 | 09:39 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
I wouldnt mind knowing the same thing, my seat leather is good BUT my foam inside is smashed on the left of the drivers side from prior owner sliding outta truck.
Old Jan 29, 2011 | 05:54 PM
njneer1's Avatar
The foam could use a replacement......but I would settle for new cloth seat bottom.....
Old Jan 31, 2011 | 03:09 PM
chadcycle 2500's Avatar
I switched my 1995 Ram 2500,The floor brackets stay where they were, unbolt the seatbottom off the frame,most of the bolts will match, One corner I used a small c clamp to keep it together.The seat belts didnot have to be changed. My passenger side was and still is like new,the bottom foam on the driver side was soft so I replaced with a bottom foam from a passenger bottom from a junk yard. It was worth the extra effort to use my whole passenger seat,the back was nice&firm,I had the cloth fixed on the driver seat& the better bottom foam,put it on the passenger side and is comfortable as well. Most of the time it has my son's car seat in it anyway. Hope this helps,JOHN
Old Feb 6, 2011 | 11:40 AM
HOOKnIT's Avatar
i switched mine 4 10mm bolts and the seat cushion comes off the seat hard wear stays there lines ups with no problem but now my seat feels brand new would like to know if there is replacement foams out there some where though
Old Feb 6, 2011 | 01:51 PM
blue24valvecummins's Avatar
i swapped out the passenger bottom with my drivers side bottom and they are the same
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
carid
Group Buy
Mar 27, 2015 07:31 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
Ryans71
Jan 14, 2015 07:52 PM
