Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
Which One 07 6.0 or 08 6.4
Old Jan 27, 2011 | 03:52 PM
LOCOCHARTER's Avatar
Default Which One 07 6.0 or 08 6.4
IM NEW TO THE SIGHT AND LUV ALL THE GOOD INFO.IM LOOKING AT AN 07 AND O8 WITH THE SAME MILES 90000 AND PRETTY MUCH SAME $.I WILL DO ALL THE UPGRDES TO FIX ALL THE PROBLEMS AND GET THE FUEL MILAGE TO EITHER TRUCK.I PULL A FITH WHEEL.IM NOT SURE WICH TRUCK TO BUY I KEEP A TRUCK UNTIL THEY QUIT.
Old Jan 27, 2011 | 08:25 PM
gunman41mag's Avatar
Moderator
If warranty isn't an issue, get the 6.4, cause you don't have to studded the 6.4, do a DPF/DELETE & you'll get better MPG, the 6.4 has a stronger tranny. NOW you have to remove the water out of the diesel every month on the 6.4 & change the two fuel filters by 15,000 miles
Old Jan 27, 2011 | 08:34 PM
Default Re: Which One 07 6.0 or 08 6.4
Get the 6.4 with a DPF delete with a Spartan Tuner.
Old Jan 27, 2011 | 09:35 PM
Keychain444's Avatar
Go with the 6.4, DPF delete and Tuner then your good to go
Old Jan 27, 2011 | 09:47 PM
BriteWhiteRam's Avatar
6.4,dpf delete, spartan tuner, they are BAD!!! If i had the cash i would have an 05 dodge, my current truck and a 6.4 ford
Old Jan 28, 2011 | 12:33 AM
Hummin Cummins's Avatar
my first trip in a 08 6.4 left me sitting on the side of interstate at -24 freaking thing just shut off. Ford diesel's are just unreliable. Hope there new one is better
Old Feb 3, 2011 | 02:40 PM
95-SimpsonOBS's Avatar
Get the 6.4, my best friend has one with an AFE stage 2 straight pipe and the spartan, its a BAD MOTHER F**KER!
Old Feb 3, 2011 | 03:13 PM
Mdub707's Avatar
Studs are still a good idea on a 6.4. Not at the power level of a tuned 6.0, but at higher power levels of a 6.4 6.0 you can only tune up to aroudn 420rwhp, 6.4 is almost 600rwhp... the biggest issue being drive pressure on them so they still blow headgaskets up towards those numbers. 6.4 will get better mileage with DPF delete/tuner than a tuned 6.0 from what I've sen. 6.4 doesn't really have a stronger tranny. They're essentially the same but a few small changes did happen. Torque Converter/flex plate setup is a little different and the pan and filter setup is different. Other than that, the hard parts are the same, they're both 5R110's...
Changing fuel filters that often is recommended on either one of them. I never go 15k on my fuel filters with my 6.0
The 6.4 is not too far different from the 6.0, same crappy head design. EGR system is better on 6.4 and WAY easier to block... 30 min job instead of a day long project on 6.0. Fuel system is way better on 6.4 too. A wastegate is a good idea on a 6.4 with real big tunes. Wide Open is designing a single turbo setup for the 6.4 as a kit now, should eliminate a lot of the issues guys are having running stock trucks with big tunes (ie drive pressure, high EGT's, lots of smoke... etc).
The biggest difference is the interiors... those 08+ interiors are so nice. That alone would be the selling point for me.
BeastFromTheEast
Sep 14, 2015 02:25 PM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
