coolant problems
Old Jan 26, 2011 | 10:59 PM
MurphyStrut's Avatar
Default coolant problems
I've been having some problems with my truck running about 10 to 15 degrees hotter at highway speeds. Also when I accelerate past 70 or so my temp gauge will rise with my speedometer??? I took it in and the shop said I needed a new radiator, so they replaced it. Problem is it is still doing it! What could it be? Thanks
05 Cummins, 160k, just exhaust and CAI for right now
Old Jan 27, 2011 | 09:23 AM
steved's Avatar
I would be replacing the thermostat, followed by the water pump...and I would inspect (read: give it a squeeze) the lower radiator hose to see if it still has the internal support spring/wire (to keep it from sucking shut).
I would also consider checking the sending unit for the gauge...at least verify the gauge is reading correctly.
Old Jan 27, 2011 | 12:17 PM
Thanks so much for the help, also. Where is the sending unit and how do I check it?
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Mike0885
Feb 28, 2015 03:16 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
