Recommended towing mods and maitnenance
Old Jan 26, 2011 | 01:56 PM
cltdba's Avatar
Default Recommended towing mods and maintenance
New to the forum, new to diesels. After years of towing with a half ton hemi I finally got the truck I wanted. My 07 5.9L is primarily used for towing. I'd say 90% of its use will be with a 5-ton bumper pull trailer behind it. Most of that time the trailer will be a light load of around 8,000 pounds. A large amount of my hauls will be through the mountains with the steepest grades around 8-9%. I bought the truck on Christmas Eve 2010 with 91k miles on it. The truck has a few mods done to it already, but I'm not sure of the extent of the modifications. It feels very zippy off the line, but I have nothing but a gasser to compare it to.
Current "Known" mods:
- S&B CAI
- 4" exhaust with muffler, unknown brand. Pipe is black though :P
I'm wanting to know what modifications I should look to make, and in what order. I'm not interested in extreme amounts of horsepower/torque or rollin coal. I want it to be reliable, get good fuel mileage and get out of it's own way when towing.
What I was thinking:
1. Gauges: EGT for sure, boost and fuel pressure?
2. A programmer of some sort, smarty?
Also, what sort of maintenance should I be doing to this truck? Keep in mind, this is my first diesel so don't worry about hurting my feelings. I need to learn. Educate me fellas.
Old Jan 26, 2011 | 02:03 PM
skinnysfd's Avatar
Im a little new to diesels here to but from what ive learned i will say u are on the right track with what you are thinking. Definatly get the gauges first because u wanna know what your truck is doing( boost,egt,tranny temp,and fuel pressure). I would say a smarty jr since you prolly dont wanna change the tranny right away. Then like i did on mine i did a fass platinum. i've also added a s&B cai, exhaust , etc... Im sure someone wiser than me will chime in but for what its worth thats what i would suggest. hope this helps ya some
Old Jan 26, 2011 | 03:45 PM
cltdba's Avatar
Thanks for the help! The smarty jr is what I was considering.
Also, please recommend any brands of gauges/pods, or other programmers.
Anyone else?
Old Jan 26, 2011 | 03:58 PM
Farmboy 2.0's Avatar
Smarty Jr and a set of autometer gauges boost pyro and trans temp if you have a auto trans
Old Jan 26, 2011 | 06:00 PM
Captain Call's Avatar
I'd look into better fuel filtration. Kill 2 birds with one stone and get an Airdog. Flush the radiator. Change the diff fluid. Exhaust brake might be nice for ya too.
Old Jan 27, 2011 | 09:16 AM
cltdba's Avatar
So you would go with an AD before gauges and programmer, or in addition to?
I looked at the S&B filter on the truck and it was clogged slam up and brittle. It appears to be their oldest design for this truck. I may need to upgrade that. I stuck a parts store filter on it for the time being. Made a big difference in power.
Here are my thoughts on the order of mods. First things first, I'll change all the fluids.
1. Gauges
2. Programmer
3. AD/FASS
4. Tranny and/or TC
5. Exhaust brake
Old Jan 27, 2011 | 01:01 PM
BriteWhiteRam's Avatar
Looks like a pretty good list so far, just make and sure to save your pennies when it comes to the transmision, they are not cheap to open up and play with
I would go Isspro or autometer 60psi boost, 1600F pyro, and transmission temp
Smarty jr. or Smarty sr., you can keep the sr. on a low level say SW2 until you get your other mods done
Fass or AD, its up to you, they are both nice units
If I had the Cash i would be getting a Goerand transmission
Old Jan 27, 2011 | 01:50 PM
sunsetsky's Avatar
Site Sponsor - Black Cloud Diesel Performance
Howdy! Welcome to Diesel Bombers! You're Going to Like it Here!
Old Feb 9, 2011 | 01:52 PM
cltdba's Avatar
Thanks for all the help guys. Going with the autometer factory match set; pyro, trans temp, boost. Then to save up for the rest.
Old Feb 10, 2011 | 10:23 AM
sunsetsky's Avatar
Sounds like a good plan. Glad you found the help you needed!
