After oil change noise
Old Jan 26, 2011 | 01:00 AM
03diesel_man's Avatar
Question After oil change noise
I did an oil change on my rig, used fleetguard filters from work. I have now noticed the fuel filter on the frame rail, the pump is really loud,not sure why asked the boss he said it could have been because it hasn't been changed in awhile. But the filter that I put in didn't have the screen around it like the old one. Anyone has heard that or know why it does that? Please let me know interested.
Old Jan 26, 2011 | 09:39 AM
Mdub707's Avatar
Because they're junk filters and don't have the water seperators. I'd use International filters if you can, they're the same as the Ford, and they're cheaper. It shouldn't be making any noises.
It could just be a different tone you're not used to if your last set was really bad. Does it sound like a normal pump whine or is it a different noise?
Old Jan 26, 2011 | 10:21 AM
I'm sorry yes they where international filters and yes it sounds like a regular whine I was just making sure, it's just loud, loud enough you can hear it over the motor
Old Jan 26, 2011 | 11:43 AM
Mdub707's Avatar
Hmmm, they're not normally that loud. I'd test fuel pressure. You can hook it up to the fuel bowl on top of the motor, take one of the plugs out and thread in the gauge, see what you get. Really the only way to tell what's going on here. At least if there is an issue with the pump if you have good pressure you wont be hurting the injectors.
Old Jan 30, 2011 | 04:41 PM
I didn't get to test fuel pressure before I left for Michigan, as I was getting on the highway I gave it alittle gas to merge and then noticed I wasn't gaining speed so I pulled over truck was running like it had a miss fire then It shut off, tried restarting it didn't want to so I waited a couple minutes. Truck started but was running extremly rough, let it idle, pump on frame rail was really loud now. Now Im going to replace the pump and fuel filter? Expensive? Or any ideas I had fuel additive in it and it's about 30 degrees out.
Old Jan 31, 2011 | 08:26 AM
Mdub707's Avatar
I bet the pump is failing, or perhaps you have a leak and you're drawing in air. A weak pump will kill your injectors. With a fuel pressure gauge you can tell when the pump is going bad BEFORE destroying your injectors. A pump is not expensive, but 8 injectors and labor are.
An alternative is the airdog 2 fuel pump, which can be had for around $650 or a little cheaper. Stock pump is a lot cheaper than this. I want to say around $250-$300, not sure.
Old Jan 31, 2011 | 11:15 PM
I bought the pump installed it, how would I know If I f'ed the injectors I drove it home very slow and not to bring it up that high in the r's but I'm not sure how long it's been slowly dying so how would I know or will I just have to find out?
Old Feb 1, 2011 | 07:30 AM
Mdub707's Avatar
Don't drive it slow. Babying these trucks is probalby the worst thing for them, the motors need to be worked. If it drives ok, your injectors are probably ok. You'll know when they become a problem, the truck will shudder and miss like crazy. It's probably fine, but a good fuel pressure gauge is still a good idea...
Did your issues go away with the new pump?
wlofton
11
Jun 26, 2018 08:58 AM
soco
Jul 27, 2015 06:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
Boatman
Mar 20, 2015 10:00 AM
J_stout
Feb 21, 2015 11:40 PM
