Possible Ingition Switch Issue?
Old Jan 25, 2011 | 07:45 PM
claybreaker 144's Avatar
Default Possible Ingition Switch Issue?
I have experienced a problem where my truck will not crank. The volt gauge is bottomed out on the low side when the key is turned and there is no crank or click out of the starter. The glow plugs don't sound like they are cycling but the fuel pump will work. Battery checked out fine, lights and other accesories don't show any abnormal current draw. I jumped the starter with a screw driver and it would crank but not start because the injection pump fuel solenoid was not energized. When I jumped the injector pump solenoid the voltage gauge jumped up and the ignition switch now worked and the truck started without the jumper wire to the injection pump solenoid. This has happened twice in the last 2 weeks and the first time it happened after I hit the manual glow switch the voltage gauge normalized and the truck would crank and start. Let me know your thoughts.
Thanks for reading this.
Old Jan 25, 2011 | 08:22 PM
Crazy's Avatar
these truck where know for ingition switch going bad
when you turn the key did check small wire at the starter see if there power there
have you check all your grounds
Old Jan 26, 2011 | 06:18 AM
Thanks for the reply
Didn't check the small wire at the starter, pretty cramped in there with the turbo and all. I know the battery ground is good, and through out my various builds on this truck I've payed close attention to grounds.
Are the aftermarket ingition switches ok?
Old Jan 26, 2011 | 07:38 AM
Crazy's Avatar
i couldn't tell you aftermarket is good or not
don't for get to check the grounds and ground straps at back of the right side of motor those are the ground for the ECM
Old Jan 26, 2011 | 05:43 PM
No ECM, removed when I converted to diesel. I'll double check the engine ground to the cowl.
cumminspwr11
12
Oct 17, 2021 03:50 AM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
