Truck turns over and wont start
Old Jan 25, 2011 | 04:54 PM
chadfoot's Avatar
Default Truck turns over and wont start
I have replaced gow plug relay module. That didnt work. Wait light comes on for 1 second and goes out and it seems the glow plug relay then short cycles. The truck turns over but acts llike the batteries are dead. I checked batteries, alternator, & starter. Also checked main fuses and all are ok.
Old Jan 25, 2011 | 06:26 PM
CARP's Avatar
I'd replace the entire glow plug system. Most importantly the controller and plugs.
Old Jan 25, 2011 | 09:01 PM
DieselCrawler's Avatar
are the plugs themselves good?
Old Jan 27, 2011 | 10:33 AM
agent_123_2000's Avatar
turns over but acts like the batteries are dead? sounds like a starter to me!!!
Old Jan 28, 2011 | 04:23 PM
m954rrider's Avatar
if it is spinning to slow i would also agree the starter is bad, are you in a cold climate? if so then the glow plug controller could be bad, jump the glow plug solenoid and see if it starts. The controller may not be telling the solenoid not to pull in.
Old Jan 29, 2011 | 11:38 PM
Sycostang67's Avatar
I throw a test light on the plugs to make sure they are good. What about your battery cables, worn, corroded cables will cause a slow cranking issue. How old are you batteries and what is the CA rating of them? The batteries in my truck tested good and were 800CA each and I thought the truck started ok. Putting in two new 1000CA batteries made a ton of difference though.
Old Jan 30, 2011 | 08:17 PM
Cowboy_Crash's Avatar
Whats a good set of glow plugs for the 7.3 IDI? looking to get some new ones for my 92 IDI
Old Jan 31, 2011 | 12:01 AM
motorcraft or buer.
