white smoke wear it shouldnt be!
Old Jan 25, 2011 | 04:20 PM
smokedout's Avatar
Default white smoke wear it shouldnt be!
What does it mean if light white smoke is coming out of the hose beside the oil pan?
Old Jan 25, 2011 | 05:24 PM
BC847's Avatar
Is it in fact smoke, or steam?
Steam/vapors is quite normal.
Old Jan 25, 2011 | 07:09 PM
timdale's Avatar
That tube is your crankcase vent, like a PCV on a gasser. No big deal to have some, of course the more your rings wear, the more blow-by (white smoke) In my truck I don't see hardly any, a little at idle in the summer, but my big truck with a C-12 cat, she puffs quite a bit at idle
Old Jan 25, 2011 | 07:18 PM
smokedout's Avatar
Its smoke and its not shy. What can this hurt and how do i fix it?
Old Jan 25, 2011 | 07:43 PM
timdale's Avatar
It's supposed to do it, it's blow-by and relieves crankcase pressure. Usually a LOT of smoke means woreout ring(s) or stuck ring(s). Try some seafoam in your oil a day or two before your next oil change. Someone on here probably knows more about the cummins crankcase relief system, I'm not real familiar with it
Old Jan 25, 2011 | 08:53 PM
sweetv8s10's Avatar
If it runs ok and dosent use much oil then I wouldnt worry about it but thats just me
Old Jan 25, 2011 | 09:20 PM
smokedout's Avatar
yeah it runs real good just kinda worried me when i seen it comin out.
Old Feb 4, 2011 | 01:45 PM
dark knight cummins's Avatar
it just shows how much pressure is getting through your crank case. i cant even find mine on my first gen. but the 24 valve is on the front and it has had a reasonable amount for quite some time. its just how broken in the engine is essentially. i wouldnt worry too much
Old Feb 4, 2011 | 04:20 PM
truckwrench1's Avatar
if you have access to a magnahelic guage then you can measure the amout of blow by you havewith nothing more than revving and watching the guage if i remember correctly 8-9 inches on a magnahelic is time for a rebuild if you have access to a dyno a manometer is a better choice and 13 inches if i remember corrctly is the cummins spec for rebuild ie= rings shot
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
ASarsano
Oct 15, 2014 05:33 AM
