6.0 stacked chips
Old Jan 25, 2011 | 03:55 PM
powerstroke250262's Avatar
Default 6.0 stacked chips
i have a 04 6.0 with sct x3 programer and i wanted to stack it with edge juice with attitude. just wondering if anyone is runnin both or if its a bad idea
Old Jan 25, 2011 | 04:34 PM
crzycummins's Avatar
well now...have you deleted the egr and had head studs put in? fill out your signature so we know what your workin with
Old Jan 25, 2011 | 04:38 PM
egr has been deleted and headstuds are on order should be here friday.
Old Jan 25, 2011 | 05:13 PM
Mdub707's Avatar
Stacking is a Dodge thing. If you have custom tunes for your SCT, you are not going to get more power out of it.
You can use an Edge monitor in conjunction with your SCT, but for monitoring only. If you could even stack the thing the timing would be through the roof. 1+1 does not = 2 in this case.
Concentrate on getting the headstuds done properly first, having the heads decked, magnafluxed, pressure tested, make sure block is flat.
What other mods do you have and what are you doing with the truck?
Are you running custom tunes right now? The stock fuel pump can't keep up with the hot tunes as it is, so adding more power now isn't a good idea until fuel system is up to par.
Old Jan 25, 2011 | 09:31 PM
i dont have custom tunes yet. i got the tunes that come with the tuner. what custom tunes would you reccomend? its a dailey driver and i have a stock fuel system and clutch but im savin for a southbend now
Old Jan 25, 2011 | 10:02 PM
PHPDiesel's Avatar
Sponsor
Just to be technical.....
There is no such thing as a "chip" for a 6.0L (or Cummins or Duramax).
There are flash programmers and fueling/ICP modules.
Old Jan 26, 2011 | 09:36 AM
Mdub707's Avatar
Correct.
Get some good custom tunes for your truck, it will be the best solution for now.
Popular ones are: Innovative Diesel (who I use), GoGo, Gearhead, QuickTrickAutomotovie (formerly known as DJ's if you do some searching and see DJ's come up).
Old Jan 26, 2011 | 11:55 AM
ok cool thanks man
Old Mar 20, 2014 | 12:14 PM
Hounddog55's Avatar
So one could use the programmer and use the edge in Stock mode for Guage purpose? Am I reading this right?
Old Mar 21, 2014 | 12:04 PM
Zejokee's Avatar
You should be driving a Dodge, not a Powerstroke.
BeastFromTheEast
Sep 14, 2015 02:25 PM
DoctorJJ
Jun 9, 2015 08:07 AM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
thumperf350
Jan 8, 2015 12:55 AM
