Wont idle...surges, black smoke
Old Jan 25, 2011 | 01:09 PM
Bazooka's Avatar
Default Wont idle...surges, black smoke
I bought & installed one of those 98 gal diamond plate axillary fuel tanks that fits under the tool box in the bed of my '95 3500. It belonged to a buddy of mine & was used but like new. I drained what little bit of old fuel was in it but apparently missed some trash that was in it. The truck ran fine until the last of the fuel was run out of the tank, then it started to run rough and not idle. I removed the tank and cleaned it and there was something (looked like skinless grapes ?!) that came out of the tank. I changed the fuel filter, but it still has problems. It will run down the road OK but still wont idle. Any ideas on what should I do next?
Old Jan 25, 2011 | 01:19 PM
blazier18's Avatar
clean injectors fuel lines maybe over flow valve needs changed too.
Old Jan 25, 2011 | 02:10 PM
Bazooka's Avatar
Thanks much blazier18...still a noob here. Do you know of a thread on how to for these?
Old Jan 25, 2011 | 03:06 PM
12Vdodge's Avatar
check the screen bowl in the fuel heater, might be clogged with some bigger stuff
Old Jan 25, 2011 | 08:46 PM
blazier18's Avatar
u can also do that 12vdodge and ur welcome bazooka and not sure but i had my friend do my over flow valve when i wasnt as smart as i was now but when im having fuel problems or sputtering i always start at the tank and come up to the injectors to find wats goin on
Jmrobinson
11
Aug 21, 2015 09:54 PM
wiremanWelder357
May 25, 2015 09:10 PM
ryank 199
May 14, 2015 06:41 PM
sootman
Jan 22, 2015 05:12 PM
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Oct 1, 2014 03:06 PM
