2001 cummins
Old Jan 25, 2011 | 09:41 AM
strokethis's Avatar
Default 2001 cummins
i have a 01 cummins with 306000 miles. but its in perfect shape. has a aftermarket clutch but i can slip it. i have a comp ,75 hp ddp injectors ,banks 4 inch off the turbo and 4 inch straight all the way back and the line from the turbo to the wastegate spliced with a pipe and a 1/32 hole in it. Air dog and my pillar pod are going in friday. whats next after all this? and what clutch do i need? double disk? help needed also pockets arent that deep. only 18 years old and have 2 diesels im buying and building.
Old Jan 25, 2011 | 02:42 PM
dukeboy_318's Avatar
do you know what clutch is in there now? How long has it been in there miles wise? my guess is you are somewhere in the 350hp range and 900 ft lb range roughly. So to allow for improvements, Id go with a clutch rated for 500 hp and 1200 ft lbs. You could do a single but itll be very rough engagement for that power so I vote dual disc. Southbend is the way to go. You get what you pay for in the clutch world in my opinion.
I personally reccomend going with a southbend street dual disc, very smooth operating when compared to the single disc of the same power holding rating. also, with this clutch, upgrading the hydraulics is not needed. and it works great for towing and backing trailers cause its so smooth. Depending on where you can pick one up, itll run you about 900-1200 bucks. comes with a new flywheel, both bearings, new flywheel bolts, starter adaptor and bolts plus the clutch plates, middle flywheel and pressure plate
Old Jan 26, 2011 | 08:12 AM
strokethis's Avatar
im not sure what clutch is in there but i know its aftermarket and its not very old at all. it was put in not to long before i bought the truck 2000 miles ago. ya thats wat i was thinking was a double disk for future building of the truck. and is there a hot unlock on my edge comp?
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Sep 20, 2015 10:52 PM
LittleBuck
23
May 21, 2015 06:06 PM
raude1
Apr 13, 2015 03:38 PM
