Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Amsoil Tranny Fluid
Old Mar 25, 2007 | 10:48 AM
Sea97Stroker's Avatar
Default Amsoil Tranny Fluid
This is going to be coming up soon on my list. The question is that the Alli says it takes 24qts for a initial fill. What is the best way to drain the converter to get as much new fluid into the system. The Amzoil fluid is pretty exspensive and i don't want to have to change it 2 or 3 times to get the maximum amount of synthetic into the system. I looked at amzoils web site and it looks to be almost identical to TransSyn fluid.
Old Mar 25, 2007 | 02:05 PM
Heath's Avatar
Authorized Amsoil Dealer
Correct, it is a perfect match for the TransSyn. Sent you a PM on some changing instructions.
Heath
Old Apr 11, 2007 | 03:20 PM
redneckbuckeye's Avatar
You would have to have the trans flushed(not recommended by my tranny guru).I would go with the transynd and just drain the fluid from the pan, change the sump and spin on and fill it up with transynd (3gal. I think).
Nate
Old Apr 11, 2007 | 07:01 PM
Heath's Avatar
Without flushing, you may only be removing 50% of the fluid just dropping the pan. Now you have a mix of old and new. I would think if changing fluid, not matter the brand, a flush would be the most thorough??
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
Ol' RED!
Dec 11, 2014 10:00 AM
smokee
Nov 7, 2014 07:40 PM
