Same Codes.... New IP and PMD
Old Jan 25, 2011 | 07:37 AM
Possmguts's Avatar
Default Same Codes.... New IP and PMD
Getting same codes after IP and PMD replaced..... and Im stuck in safe mode.
-94 King Cab Long Bed Lowrider 3500 HD 6.5 TD
-16" Alcoa aluminum wheels with long lugs.
-Rebuilt Stanadyne IP and new style PMD.. 1-14-11
-3" no cat straight back exhaust with 5" tip.
-Drop spindles, lowering shackles with bags.
-High Idle mod
-Heath Turbo Master
-Heath Max E Torque Chip
New LP and I just replaced my IP. It came with a new gray PMD. At times the truck will start and run just fine and dandy. But then it will start shutting down the fuel and the engine light comes on. I will be barley able to get 2k RPMs out if it when its doing this. Then out of nowhere it will start fine and run fine again for a while. Sometimes I can go 2 days with no issues, and sometimes I have to drive it that way for a day or so before it will straighten out again. Seams to go all to hell more when at idle for a short while. Does not smoke.
Codes 17, 18, 35 and 36 keeps coming up.
Codes all point to the pump still. same codes I had before I changed the pump. The pump is a Stanadyne updated rebuild 5068.
I dont get this figured out soon, someone out there is gonna get a cheap truck, that they can fix their self.
Old Jan 25, 2011 | 07:57 AM
Crazy's Avatar
Ha Scott i know talk to phone about few things one ?? coming mine here is new PMD is in front bumper i can't remember where said it was at if it is the one thing i was thinking about maybe that harnesses is bad shorting out at time i know you have try just about every thing and put out lot $$$ so far and nothing working did you ever try running fuel out 5gal can yet see if wasn't suck air from the tank to LP that would set them codes off also
Old Jan 25, 2011 | 12:04 PM
Possmguts's Avatar
Ok.... no promises, but I found that my filter inlet fuel line was kinked and causing a restriction.... The IP was probably cavitating and causing the optic sensor to go haywire causing 17, 18, and 35 codes.
I drove the truck in town and on freeway and let it idle for a long time and I have no codes at this time.
Ill drive it a few days again and wait and see what happens. Fingers are crossed that was all it was. I must have kinked it reinstalling it after the IP installation.
