I hate 24V's
Not really just when there fueled by the vp-44 and not a P-Pump
So i bought a 2000 and if you rev above (guessing no tach) 1300 RPM the throttle goes no more you push to the floor and it just stays the same then I can shift and back up to 1300 rpm
this was someones conversion project that I am now getting to
Ideas?
when I had my quad box unhooked this happened. Someone suggested the map sensor would need to be unplugged from the quad harness and plugged back into factory position. Instead I put my quad box back in. Worked perfect after that. I would check map sensor.
thanks alot man sorry about the miss post new to the site, i read somewhere about that and i wasnt sure so i figured i would try to find some people who know there stuff. do you know if buying a upgraded fuel plate would change that any?
Well with no OBD II port i cant scan it so I took to cummins and they said it was reading out on the ECM idle switch low voltage something indicating the TPS so I changed it with one I had that was good and same issue
tps not giving it full throttle?
