7.3l idi tack problems
Old Jan 24, 2011 | 07:22 PM
jmac's Avatar
Default 7.3l idi tack problems
i have a 91 ford 7.3l and the tack works when you rev it up but doesn't work when it idles and it's making my transmission jump in and out of gear under a load but if i unplug it the transmission works fine i have herd it could be the tack sensor and some people has told me it could be the transmission cpu has anyone had this problem before?
Old Jan 24, 2011 | 07:38 PM
DieselCrawler's Avatar
tach sensor is ford only item, costs about 70 bucks or so. on the timing gear cover on left side of engine on top is a 2 wire sensor threaded into the housing. unthread it and clean it off, see if that helps. if not u need a new sensor.
Old Jan 24, 2011 | 07:46 PM
jmac's Avatar
thanks i clean it already so i will get me a new sensor from ford and see if it fixs the problem.
Old Jan 24, 2011 | 08:17 PM
defarmer's Avatar
mine does the same thing. drops to 0 at an idle. going to try the cleaning
gzmak7
8
Apr 7, 2017 03:17 PM
wildhorsemfg
Show And Tell
Sep 20, 2015 11:26 AM
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
Bstehle
Feb 3, 2015 07:24 PM
Blue Briar
Oct 5, 2014 08:23 AM
