rocker arm ratio
Old Jan 24, 2011 | 03:42 PM
banditsdiesel's Avatar
Default rocker arm ratio
anyone know exactly what the rocker arm ratio is on the 98.5-02 24 valves are
Old Jan 28, 2011 | 06:32 PM
after a few phone calls and some extensive research i found the rocker arm ratio. the cummins 24 valve is 1.85:1 and that applies to the 98.5-07 vp44 and common rail trucks. so to all those out there loooking at cam upgrades do the math and check your clearances before you put in a larger cam. im in a crap storm right now because the head was not setup correctly for my cam. and has bent the valve springs and ruint all the valve seals. all because the clearance wasnt right. so make sure your cam is not to big. so to figure your valve lift the formula is== cam lift times 1.85= valve opening/ valve lift... example. stock cam is .265 lift on exhaust lobes, so it would be
265x1.85=490.25 so your lift is 490 on the valve opening.
tylerjp34
Sep 16, 2015 03:12 PM
Jmrobinson
Aug 20, 2015 07:56 PM
99dodge
Dec 15, 2014 04:56 PM
Shawnsr1
Dec 13, 2014 09:43 AM
