2 cycle oil
Old Jan 24, 2011 | 03:31 PM
dodgeflatbed's Avatar
Default 2 cycle oil
I started running a little 2 stroke oil in every 4 or 5 tanks to clean out my injectors.... one day i shut my truck off and it wouldnt start back up... Wer changed the lift pump, put in the in tank conversion, with smarty without smarty..... all had no results. They pulled 2 cycle oil out of my tank and said that might be the problem. has anyone heard of this going so bad....?
Old Jan 24, 2011 | 06:04 PM
BriteWhiteRam's Avatar
Never heard of any problems with running 2-stroke oil, i see no real benefits to it either, but i have never heard of it causing fuel system break downs, sounds like they are trying to blame something they dont know about
If anything it might be bad/dirty fuel, not the 2-stroke oil thats causing the problem
Old Jan 24, 2011 | 06:08 PM
bobcat67's Avatar
no it shouldn't i'd almost say it couldn't be the 2 stroke, weirder things have happened though
Old Jan 24, 2011 | 06:11 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i dont think 2 cycle oil has anything to do with your problems.
Old Jan 24, 2011 | 09:45 PM
dangerous1965's Avatar
i run 1 ounce per gallon sometimes a little more always! been about 20k and no problems! Gotta put something in this crap diesel to lube everything! how the hell did they pull it out of the tank? Who's "they" and were you running straight oil?? Start simple check your pressures several things in the fuel system will do this! CP3 PRV etc......
Old Jan 24, 2011 | 11:52 PM
bobcat67's Avatar
I think you need to take it to a legit shop, the one you're at sounds shady
Old Jan 25, 2011 | 12:22 PM
Deezel Stink3r's Avatar
Nearly impossible, 2 stroke oil dissolves itself in the diesel. Just get a glas full of diesel and pour some droplets of 2 stroke in it. Don't stirr.
You will recognize it is made to mix itself.Or did you fill up and then adding 2-stroke oil? That may take a bit longer to dissolve.
You mean they pulled the 2 stroke oil/diesel mixture? Sounds to me "someone" made a bunch of money with success with a dirty fuel filter...
Old Jan 25, 2011 | 12:55 PM
MTmega's Avatar
Yeah, I second everybody else's reply. Find a different shop. I've ran a half quart of ATF with every tank for 80000 miles on my '06 and never even heard of people having problems UNLESS they were running something that produced ash when combusted. I believe MMO was one of these but most 2nd gen guys I know have all been running Walmart brand supertech 2-stroke for 10 years with no problems. I realize they're VP setups but just saying with the 2-stroke, highly unlikely that caused it.
Old Jan 26, 2011 | 09:09 PM
RUSS83's Avatar
ONLY THING THAT I KNOW THAT WILL MESS WITH YOUR INJECTORS AND PUMP IS OFF ROAD FUEL I HAVE SEEN A 2005 AND A 2003 GET MESSED UP BY RUNNING OFF ROAD IN THEM AND THE TWO TRUCK WERE 1600 MILES APART JUST MY .02
Old Mar 28, 2011 | 10:57 AM
big-c's Avatar
i have ran the ashless 2 stroke oil from wally world for 70.000 mile with no issues 1/2 ounce per gallon of fuel for lubrication
