bents valves
Old Jan 24, 2011 | 11:00 AM
theenzo2's Avatar
Default bents valves
I had fire rings installed on my 2008 Dodge 2500 hd, 6.7L. Three hundred miles later I took the truck back in for a required re-torque. When I did that, the mechanic who had done the work called me and told me that there was a valve sticking up and it would not go back down and additionally, he could only locate one keeper. I had driven the truck very gently between the installation of the fire rings and the re-torque. Additionally, I had turned all of the controllers off after the fire rings were installed. I am towing my truck to a third party shop to have the engine disassembled. I need to find out if the second keeper on the valve somehow got into the engine oil pan. If the keeper is in fact found in the pan I am planning to press the mechanic who installed the fire rings to re-do the job at no cost to me. If on the other hand the keeper is not located in the engine I assume the machinist who cut the rings must have mistakenly not put it back on in which case, I am going to press him to pay for any damage caused by his negligence. My question is this: 1.) has anyone ever had a similar problem and 2.) do you agree with my assumptions and the plans I have. I am afraid that this will end up in a lawsuit and I just want to make sure I am doing everything right.
Old Jan 26, 2011 | 09:48 AM
barkrulz's Avatar
Not sure what the diameter of the return holes is, or the keeper for that matter. If it could fit in a return it's possible it's in the pan, but i think it would be more likely to hang up some were.
Either way, not installed or installed incorrectly and popped out, i think you're after the same guy. If it's not a common problem for them to come off. I've not read or heard of it happening. I have lost a few during assembly (on gas heads), and if i hadn't gone and checked every valve spring after completing the job, I would have never known it popped when i released the spring compressor.
I think i'd get a manual and read up on the procedure for removal and installation of the valves and keepers. I'd get a keeper and check it's size verse the oil return size if it isn't found in the pan.
Oklahoma24v
Jun 1, 2015 07:24 PM
DieselCowgirl4x4
Apr 1, 2015 01:22 AM
Hutch58
Mar 21, 2015 12:13 AM
