grid heaters
Old Jan 24, 2011 | 08:59 AM
cummins95's Avatar
Default grid heaters
should they be kickin on when the truck is running? it was -16 here this mornin (truck was NOT HAPPY about that one) n they are cycling every couple of seconds.
Old Jan 24, 2011 | 09:06 AM
Pyro690's Avatar
Yep. They cycle for awhile, can't remember the time/heat limit. Or just get it up to 20 mph or so and they stay off.
Old Jan 24, 2011 | 09:12 AM
cummins95's Avatar
well that explains it, my speedometer doesnt work so it never gets to 20 mph hahaha
Old Jan 24, 2011 | 09:24 AM
Pyro690's Avatar
Thought there was an engine or air temp sensor that had a part in this also. Some one should know.
Does it cycle all the time?
Old Jan 24, 2011 | 09:31 AM
cummins95's Avatar
no only when its real cold. n it seems to stop once the water temp gets up to like 180ish
Old Jan 24, 2011 | 09:36 AM
Pyro690's Avatar
Ok. Sounds like they are working like they should. What is the problem with your speedo?
Old Jan 24, 2011 | 09:58 AM
12Vdodge's Avatar
yup, mine does the same thing....i'll try to find the web page I read that describes how many second they stay on before startup and how many minutes they cycle after after startup depending on the air temp. Not to hijack the thread, but my truck this morning just did not want to stop smoking white/blue even after the temp. gauge reached the bottom of range....is that to be expected with these cold temps, or is that the high mileage talking?
Old Jan 24, 2011 | 10:11 AM
cummins95's Avatar
when i went to come home after the STEELERS game last night, it was -10 n she was blowin white smoke the whole way. my fuel is definitely treated well enough, so i think its just cuz of the extreme cold. but as for the speedo, when i put the 5 speed in, it read about 15 mph off, so i switched the gear in the tail end of the transfer case n now it dont work at all. do u have to pull that tail housing off n switch both the plastic speedo gears?
i think the smoke is just condensation cuz of the huge difference in temp, say ur cruisin egt's are750-800, its comin out the pipe into -10. prolly just freezin the water in ur exhaust gas
also, have u ever done the timing on ur truck dustin?
Old Jan 24, 2011 | 03:00 PM
12Vdodge's Avatar
nope, as far as I know the timing is still stock. When I came home this morning (10am) from class it was still only 5 degrees or so and it cleared up so who knows.....I guess we just arent used to these colder temps!
oh, and no luck on that web page
Old Jan 24, 2011 | 03:35 PM
cummins95's Avatar
well if ur ever up this way get ahold of me, i got the tools to set it.
