Dash dead
Old Jan 23, 2011 | 10:19 PM
navy_welder's Avatar
Default Dash dead
Well my cluster went out and I'm wondering will a dash from a gas truck work on my diesel in my sig
Old Jan 23, 2011 | 10:42 PM
turbostang7's Avatar
i have heard of gas clusters in the diesels, but the guages don't read correctly for some reason? whats wrong with yours?
Old Jan 23, 2011 | 11:01 PM
Shorted out in 3 spots
Old Jan 23, 2011 | 11:19 PM
GuyWithA24Valve's Avatar
A bunch of warning lights come on from what i hear. I'm not sure if the tach reads the same and you wont have the Wait to Start light or the Water in Fuel light.
ah gotcha, best bet is to find a diesel one if you want them all to work right.
Old Jan 24, 2011 | 04:39 AM
dukeboy_318's Avatar
yep stay with a diesel dash, also keep in mind that youre mileage will not be correct even with a junkyard diesel dash as the mileage is recorded in the dash unit itself, not the pcm or ecm
Old Jan 24, 2011 | 07:11 PM
I thought that the PCM stores the mileage on a 02 and a 01 cause of the new system they used in it to be able to read the Obd codes from the dash
Because I looked into it and for a 02 dash you have to replace it with a 02 dash but the 00 and 01 are interchangeable
Last edited by navy_welder; Jan 24, 2011 at 07:11 PM. Reason: Automerged Doublepost
Old Jan 24, 2011 | 08:23 PM
i can read my codes from the dash too, it started in 2000, but i put a 1998 dash in mine, wont give the codes, but didn't throw any either.
Old Jan 24, 2011 | 10:52 PM
I dont know much about it, i just know what Ive read and researched on the web, they say it can be swapped but the mileage wont be the same and if you go to a gasser dash, sometimes codes will trip. I do know that the federal government mandates that the odometer mileage be recored in the dash and it cannot be tampered with or reset. Been that way since the early 50s.
burndiesel
10
Feb 7, 2023 01:15 AM
mike350fordpower
Jul 17, 2015 08:51 AM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
