93 not as quick as i think it should be!!!
Old Jan 23, 2011 | 09:55 PM
smokedout's Avatar
Default 93 not as quick as i think it should be!!!
Well i bought a 93 single cab 2wd 5spd yesterday, so i spent the day cleaning it up and working on the pump. I did just about everything that i could find on this website to the pump free wise. The guy i bought it from said it had 150hp injectors and a turbo from a 98 it also was already straight piped and had an intake. Before i messed with the pump it smoked alot due to the injectors even though i didnt know they made them that big but anyway it still is not very quick, i dont understand. C ouple of my buddies truck are just turned up and they feel alot quicker. My tope end is pretty good. I had a 95 with no fuel plate and the 370s and i feel like i could had run laps around the 93. aNY ADVICE WOULD BE GREAT
Old Jan 23, 2011 | 10:03 PM
901stgen's Avatar
3200 governor spring. Open that bad boy up! haha... They're about 20 bucks and you wont believe the difference it makes!
Old Jan 23, 2011 | 10:37 PM
BRE's Avatar
BRE
X2!
Old Jan 24, 2011 | 11:24 AM
Levi Miller's Avatar
fuel pin and x2 on the spring best 130 bucks youll spend you can have injectors an a turbo butt it dont do any good if your truck cant fuel emm
Old Jan 24, 2011 | 11:44 AM
smokedout's Avatar
true very true
Old Jan 24, 2011 | 12:10 PM
IrishChamp's Avatar
Find a local Bosch store, the vendors I spoke with wanted $40 or $45, I got the 366 spring for $20 locally.
Old Jan 24, 2011 | 04:57 PM
901stgen's Avatar
I got mine from puredieselpower.com for 20 bucks plus shipping.
Old Jan 24, 2011 | 05:54 PM
IrishChamp's Avatar
Cool, glad all the vendors aren't charging double.
Old Jan 25, 2011 | 09:03 AM
1stgen350's Avatar
my 93 is very fast but its an auto
Old Jan 25, 2011 | 11:01 AM
Thekingrulz69's Avatar
Ya, what they say, plus, take this into consideration. The stock lift pump on our trucks are crap. So if you still have the stock lift pump, upgrade that bad boy. Install an aftermarket electric fuel pump because my truck (without bigger injectors) defuels at about 2200 RPM, but i also have an aftermarket power pin and the 3200 spring. I just got my lift pump in, its a holley black, but you can go with whatever you want. i recomend you get bigger fuel line, draw straw, and a high flow fuel filter. I got everything but the lift pump at vulcanperformance.com. Just waiting for the mail. After that, she should haul *** and blow black on those silly little priuses.
dutchsupreme
Diesel Engine Conversions
May 25, 2015 08:48 PM
May 8, 2015 11:10 AM
12thman
Jan 20, 2015 03:22 PM
