cold start problem
Old Jan 22, 2011 | 06:27 PM
Ramman64's Avatar
Default cold start problem
Hi I am having problems starting in cold weather when it has been sitting for a while. But if its plugged in it would start no problem . On a cold start I would have spray it with brake cleaner as I know this is not good for the engine. What I am looking for is if anybody has had this problem and could share their information as to what they did to correct it. I am guessing that my grid heater might be shot ????
Old Jan 24, 2011 | 02:13 PM
ykdodger's Avatar
Hey there Ramman what kind of cold temperature are you talking about here. I have the same truck as you. I know where I'm to in Canada if it gets down to -25C (-13F) and under I have to plug it in, if not she is not to happy to be starting.
Old Jan 24, 2011 | 08:39 PM
Ramman64's Avatar
I live in southwestern Ontario and it gets cold here too. LOL but my other question is if my injectors are bad would it be all the time I go to start the truck it would give me problems.
Old Jan 25, 2011 | 12:35 PM
steved's Avatar
When injectors first start to give problems, its generally a hard start cold, but normal start warm. Not saying this is your problem, just answering your question.
Old Jan 25, 2011 | 06:53 PM
Dodge4829's Avatar
starting the truck with break clean isnt to bad but..... if the grid heater kicks on when ur doing this it will cause problems
Old Jan 27, 2011 | 04:19 PM
kylemckay's Avatar
have you checked for power at the grid heater when you first turn the key on?
Old Jan 31, 2011 | 05:24 PM
TeckJohn's Avatar
I have a 2005 dodge 3500 and it had a cold start problem and it was loose injector tubes
burndiesel
10
Feb 7, 2023 01:15 AM
Mike0885
May 27, 2015 12:07 PM
thurobred1320
May 5, 2015 09:26 PM
ajs93hd
Feb 25, 2015 09:28 AM
custom7.3
Nov 23, 2014 10:44 PM
