hy35
Old Jan 21, 2011 | 10:55 PM
caylebk's Avatar
Default hy35
i'm only seeing about 24 lbs of boost can i get more and is it unsafe to remove the wastegate. i'm upgrading in a month or so
Old Jan 21, 2011 | 11:00 PM
RAW's Avatar
RAW
I plugged mine, and was able to make 29PSI according to my EJWA. I ran it that was for about a 8 months. I have since sold it, and keep in touch with my buddy I sold it to. It is still running strong.
Old Jan 21, 2011 | 11:23 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Mine is also plugged... Cut hose... Stuff a bolt in it!
Be carefull not to put tooo much boost to her. Drive pressure on stock turbos are EPIC! You can damage head bolts! Been there done that
Old Jan 21, 2011 | 11:38 PM
RAW's Avatar
RAW
I have yet to see a HY35 with a hose on it. HX35's do though.
Old Jan 21, 2011 | 11:45 PM
I have an Hx35 !
How much difference is there between the 2
Old Jan 21, 2011 | 11:48 PM
01quadcab's Avatar
thats all i got out of my hy was around 26 using the jhook from ts
Old Jan 22, 2011 | 11:10 PM
caylebk's Avatar
can you push too much boost with the wastegate off? from what i understand they wont push more than 35
Old Jan 22, 2011 | 11:35 PM
jake 94's Avatar
With a HY you probably won't even hit 30 but with my HX edge juice+hot and 150 sticks I could hit 50psi
Old Jan 22, 2011 | 11:41 PM
caylebk's Avatar
my friend has a 2000 cummins with the hx any reason why they swithced?
Old Jan 23, 2011 | 12:04 AM
DanLowe's Avatar
Is his 2000 a manual?
