turn signal and brake light problem
Old Jan 21, 2011 | 08:55 PM
bigpipes73's Avatar
Default turn signal and brake light problem
my turn signals all the way around and brake light on my 94 7.3 are not working. I have tried changing the signal flasher and changed all of the light bulbs, also have checked all fuses. My question is could my turn signal switch be bad? Oh i have also changed the little brake light switch button on the brake pedal. Would the brake lights run through the turn signal switch too? There is a lot of play in the the switch its self!
Old Jan 22, 2011 | 06:30 AM
North County SAR's Avatar
I had a similar issue, how do your body grounds look? I replaced mine and added a few and everything work fine now, though I still need to replace the turn signal switch because the internal catch is worn out.
Old Jan 22, 2011 | 07:34 PM
dolmstead2007's Avatar
My friend just had this happen with his 94 lost his all turn signals and brake lights and it turned out being his turn-signal switch. so could very well be your problem
moparman70
Jul 30, 2015 12:38 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
