Cold fuel plugging fuel filter...
Old Jan 21, 2011 | 11:28 AM
moparious maximus's Avatar
Default Cold fuel plugging fuel filter...
It was -14* here this morning and both trucks started plugging fuel filters, my truck had the yellow-ish wax that I'm used to seeing (paraffin wax I'm assuming), now my dads truck (the 1-ton) had a really dark caramel colored slime on the filter that I've never seen before. I warmed his filter up and collected the gooey stuff and it started setting up in a container in our shop and its around 50* in here... What is this ****?
We did buy fuel at different places, we both use the Power Service additive ( I dont really know if that helps or hurts gelling, we use it to lube the fuel).
Just curious if anyone has seen this caremel colored slimey goo before?
Old Jan 21, 2011 | 11:30 AM
Never seen that. Which Power Service are you using? The white bottle?
Add a triple dose to the tank and wrap the fuel filter with an electric heating pad and plug it in for a couple of hours. Trying to keep these things running in the cold sucks I know all about it.
Old Jan 21, 2011 | 11:44 AM
Yea, the white bottle, (supplement-cetane boost).
We called an oil-fuel sales guy, and he says it could be the fuel supplier's additive fighting with the Power Service, I guess stations around here dont buy actual (blended) fuel, they just add an additive. I could really use some #1 right now!
Old Jan 21, 2011 | 11:50 AM
Red_Rattler's Avatar
High Tech Redneck
I've never heard of a northern fuel supplier not buying or supplying blended fuel, thats crazy that they dont and I'd be finding a new station thats does...
Old Jan 21, 2011 | 12:18 PM
arobertson's Avatar
run kerosene in your fuel it work great for me.
Old Jan 21, 2011 | 12:33 PM
Some guys even run a little gasoline. Never tried it myself.
Old Jan 21, 2011 | 12:46 PM
arobertson's Avatar
gas is good only bout half a gallon a tank and only in a emergency. it will eat you orings in you pumps,but i does work beter than most thing from the store.
Old Jan 21, 2011 | 12:54 PM
Farmboy 2.0's Avatar
If you can find some winterezed schaffers additive which is awesome or run way more of the Power Service than they recommend. I usally run about 16oz to a tank and had great luck when I lived in Iowa
Old Jan 21, 2011 | 01:06 PM
GuyWithA24Valve's Avatar
I have never had a problem with filters in my truck plugging up in the winter and I've had if for 3 winters now. It's about -18 here right now and my truck is running fine. I would say that it's gotta be the fuel because the powerservice products usually all help to keep your truck from gelling but i don't remember if the slick diesel does. I think it does.
Old Jan 21, 2011 | 01:10 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
im wondering if this is some kind of biodiesel. like soy oil waxing up. i know a fuel guy around here that supplies several countys school buses said he had trouble with this. several buses had to be towed a couple years ago. the soy oil separated from the diesel. some countys must of got more soy than they was suppose too. he had a 10 percent mix in his tanks of soy oil. he said it only happened in cold weather. i never saw untreated diesel that power service would not treat but i only saw about -20 weather too.
