40lbs of boost
Old Jan 20, 2011 | 06:29 PM
TN12valve's Avatar
Default 40lbs of boost
with my wastgate blocked off i was getting right at 40lbs of boost i ran like this for awhile but it kinda hit me that my headgasket may not last much longer so i took it off. with my fuel pate came a boost elbow i dont think its the kind u can adjust. if i put this on would it push that much boost?
Old Jan 20, 2011 | 06:39 PM
Whit's Avatar
Site Mascot
no prolly not.................anything over 32 psi is so superheated its killin yer egt's anyway
Old Jan 20, 2011 | 06:50 PM
cummins95's Avatar
x2 set it right around 30-35. above that is just hot air
my egts are alot cooler n more controllable with the dtech at 40psi than my stocker pushin 50.
Old Jan 21, 2011 | 10:15 AM
TN12valve's Avatar
yeah stock im getting like 28 max boost so im gunna install the elbow n see how it works for me i would feel much better about having an elbow vs. a clamp! haha
Old Jan 21, 2011 | 10:25 AM
Farmboy 2.0's Avatar
Alot of that has to do with the increased CFM of a larger turbo compared to a stocker. Your pushing more air with the 62 over a stocker all through the range of the turbo
Old Jan 21, 2011 | 02:45 PM
BRE's Avatar
BRE
Yea i would back it down a bit and go with 32-35 like these guys said.
Old Jan 26, 2011 | 08:39 PM
RUSS83's Avatar
JUST WONDERING IS IT NORMAL TO RUN 12 POUNDS OF BOOST AT 1800RPM AND AT 60
Old Jan 27, 2011 | 12:06 AM
5.9sledhead's Avatar
Ya that's about right where mine is at 60 also
Old Jan 27, 2011 | 08:59 AM
Pyro690's Avatar
You can adjust a non-adjustable boost elbow by drilling it out some. Just go in small steps till you get it 30-35#.
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
