Adding 2 stroke to a 6.7 good or bad?
Old Jan 20, 2011 | 06:08 PM
malibumw's Avatar
Default Adding 2 stroke to a 6.7 good or bad?
I have read a lot on fuel additives and 2 stroke oil, but it refers mostly to the older trucks. I know the newer engines are built to use the ultra low sulfar fuel, but is it OK to use 2 stroke in the 6.7 for some extra lube or will it hurt it?
Old Jan 20, 2011 | 06:16 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i do with mine but i got deletes. if your truck is stock dont do it.
Old Jan 20, 2011 | 06:21 PM
Miller's Avatar
iv never heard of that... how much per tank or how often...
Old Jan 20, 2011 | 07:45 PM
diesel pap's Avatar
they are a thread on this. i give mine about a qt every few tanks.
Old Jan 21, 2011 | 09:11 PM
coors_man_2005's Avatar
i have never heard of it just helps lube everything up? a freind of mine has an 01 cummins said when he changes his oil he dumps it in his tank with mostly full tank of fuel what u guys say about that on the old or new with deletes
Old Jan 21, 2011 | 09:17 PM
diesel pap's Avatar
i would want it filtered. i dont really want to do it in my common rail.
Old Jan 21, 2011 | 09:31 PM
ya i thought it was kinda different just remembered him saying that sojust threw it out there
Old Jan 21, 2011 | 09:34 PM
diesel pap's Avatar
years ago it was common to see guys do this with sawmill power units and equipment around here.
Old Jan 22, 2011 | 10:11 AM
malibumw's Avatar
I started this thread because I have a stock 2010 (6.7) and I get 13 mpg with winter fuel (16 mpg summer fuel). I have had this 3 months and have over 18000 miles. I was told the 2 stroke would increase mileage. Any other Idea's on how to increase MPG feel free to throw those out as well! Do the Deltes work? Thanks for your help.
Old Jan 22, 2011 | 10:18 AM
DAFBFD58's Avatar
deletes will work wonders but you need a programmer to keep your truck running. Other wise just unplug the egr connection. you will get a soft code but it wont do harm. It should give you a few more mpgs
