what turbo is best
Old Jan 20, 2011 | 05:53 PM
blazier18's Avatar
Default what turbo is best
im gonna run 5x14's competition dv's timing to 20* head studs all pump work and a 0 plate and get water meth in a month or two i haul around 3500 to 4000 pounds everyday in the summer and will a full ceramic 550 hp clutch hold up to all that
Old Jan 20, 2011 | 06:16 PM
cummins95's Avatar
i wouldnt go ceramic for the clutch. they are really grabby, either in or out n if ya slip em, u can weld the disc to the flywheel, just ask nate (12valvetater). dont spend all that money buildin up the motor then skimp on the clutch or u'll destroy it. i love this dual disc, but u might wanna go with a higher plate load for what ur lookin at
Old Jan 20, 2011 | 06:55 PM
blazier18's Avatar
heard t6hrough the grape vine a dual disk u cant change gears real fast and there really hard to push down
Old Jan 20, 2011 | 07:18 PM
cummins95's Avatar
no i cant slam gears but i still have the stock hydraulics. im gonna order the upgraded set n see if that helps.
Old Jan 20, 2011 | 07:32 PM
blazier18's Avatar
that sounds like it should help im shootin for 600 hp
Old Jan 20, 2011 | 07:43 PM
94 12valve's Avatar
upgraded hydro will help some ... but a dual will not shift like a single, slam shifting these 4500's is a great way to blow them up
why are you gonna run such a big dv? 181's would be great
Old Jan 20, 2011 | 07:56 PM
blazier18's Avatar
smoke and a little extra power
Old Jan 20, 2011 | 07:59 PM
94 12valve's Avatar
smoke add's extra heat ... which is what your trying to loose the extra power will come from the bigger injectors and charger
Old Jan 20, 2011 | 08:01 PM
blazier18's Avatar
im workin on that too ha ha 5x14's and pump work and ive heard timing will drop egts and timing will increase
Old Jan 20, 2011 | 08:04 PM
94 12valve's Avatar
timing will help but the larger dv's kinda defeat the purpose
