code crazy!
went out this morning to fire up my truck and the truck threw the check engine light.... cycled the ignition 3 times and this was what it gave me....
1693
237
1475
236
522
just had the headgasket done about 3 weeks ago... the truck also cuts out under boost and starts missing at idle after u let off out of the boost.... the truck also cuts out getting on the highway? any advice?
1693
237
1475
236
522
P1693 DTC Detected in PCM/ECM or DTC
Detected in ECM Companion code. This code just means there is
more codes present in either PCM and/or ECM
PO237 Map Sensor Voltage Too Low MAP Sensor failure or disconnected
P0236 Map Sensor Too High Too Long Wastegate problem or smoke switch left on
What is the fuel pressure?It is the most important thing on these truck to have a fuel pressure gauge.
Sounds like the map sensor is not plug in or is bad.
P0522 Oil Pressure Voltage Too Low Oil pressure sending unit (sensor) voltage input below the
minimum acceptable voltage.
P01475 Aux 5 Volt Supply Voltage High Sensor supply voltage for ECM sensors is too high.
Sounds to me like you have an ECM connection problem, or a ground problem. It has always been my experience that when you get this many unrelated codes, it's a ground problem somewhere in the system...
would this be causing the cutting out a surging under load? and where would be the best place to start? im getting the sending unit fixed.... it starts surging at 17 psi.... it has a aftermarket lift pump.. as well as a power edge chip.. i dont have a fuel pressure gauge
it does it with the chip off and on any of the stages doesnt seem to change? and also what about the apps sensor?
have you completly removed the chip and harness from the truck, i mean every wire of it? This is exactly what my truck did when my edge shorted out in january of 09. I ended up chasing all these unrelated codes and it was simply the edge and its harness, removed it, codes went away and the truck ran fine
if the wiring on the edge is grounding out it could be causing issues best thing to remove something to see if it helps. it's cheap to do that rather than play change out all these parts that are not bad till you find what is.
guess i didnt really test with the box off or not. turned it off and no problems at all.... leads me to believe the box is bad just like u said.. i also adjusted my apps sensor and it feels alot more responsive. any suggestions on a good programmer? what about the edge juice w attitude?
http://www.tstproducts.com/985-02dod...tpowermax.aspx
ok so i figured out with my edge box off my truck doesnt do the cutting out and sputtering so i left it off for awhile... i went out yesterday and disconected the box from the wiring harness. was that a mistake? now my truck wont go over 9psi and doesnt even have ennough power to get out of its own way and runs like dog s*&%. plugged the box back in nothing changed
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
