Timing Adjustment
Old Jan 19, 2011 | 08:26 PM
kieron_kohlmann's Avatar
Default Timing Adjustment
How to i advance my timing the easy way? I need to go a few degrees.
Old Jan 19, 2011 | 09:07 PM
tiremann9669's Avatar
Try posting in the 1st gen section since thats what you have. I know on the p pump trucks you need a kit, but I have heard of it being done on the 1st trucks by moving the pump.
Old Jan 19, 2011 | 09:09 PM
P-pump on the first gen. should probably update it.
Old Jan 19, 2011 | 09:35 PM
Oh yea you left that out, you need a kit to time the p pump
Old Jan 19, 2011 | 09:37 PM
ltr450's Avatar
there is a you tube video how to do it
Old Jan 20, 2011 | 07:12 AM
Flight911's Avatar
I want to adjust my timing on my 96 but I don't like anyone working on her but me. I guess I need to buy the setup to do it huh
Brandon
Old Jan 20, 2011 | 07:23 PM
c12vpwr's Avatar
u dont need a kit u have to get the motor and pump on top dead sinter pull the timing gear cover on front of motor loosen the nut on the top gear for the pump so u can turn the timing on the motor while the pump stays the same if im wrong tell me i had a buddy do my truck
Old Jan 20, 2011 | 09:05 PM
problem is getting the gear off that is torqued to 200ft lbs. thats where the puller comes in.
Old Jan 21, 2011 | 01:11 AM
c12vpwr's Avatar
whats the problem with getting it off i have done this a couple of times and not that hard
Old Jan 21, 2011 | 01:17 AM
OK and how do you know what you're setting it at.
