Homemade twins? Could use some help
Old Jan 19, 2011 | 05:57 PM
5.9sledhead's Avatar
Default Homemade twins? Could use some help
Iv been thinking of making a twin turbo kit out of an hx55 or ht3b an using the stock turbo as my primary. Good idea or not? The hardest part is going to be building all the tubing but I don't know how to bend 4inch with out the ripple effect. Got any ideas on how to build it? I heard the hx55 spins opposite of an ht3b does it make a differencE in flow an tubing design? Pics of any twin turbo kit would be of great help thanks.
Old Jan 19, 2011 | 06:04 PM
RAW's Avatar
RAW
When I did mine, I bought lots of 45's and 90's of 3" and 5" exhaust pipe. Then I just mocked everything up, cut, and welded everything to fit. It's not the cleanest, but it works 100%!
https://www.dieselbombers.com/5-9l-2...urbos-2-a.html
Old Jan 19, 2011 | 06:07 PM
Farmboy 2.0's Avatar
Talk to RAWilliams he is usaully in the 98.5-02 section but he just built his own set of twins about 3 month ago or so. I think he could give ya some hints on how he did it. And if I was building a set of twins Id go for something like a hx35 over and s400. Your a moderator now Ryan?
Old Jan 19, 2011 | 06:11 PM
RAW's Avatar
RAW
Yes
Exactly what I did!
Old Jan 19, 2011 | 06:13 PM
Cool Congrats
Old Jan 19, 2011 | 06:16 PM
What size of wheels on the s400? How much did the turbo cost? Oh ya doesn't make much sense to try an make the hot pipe any bigger considering that's what the outlet is any way huh.
Old Jan 19, 2011 | 06:20 PM
RAW's Avatar
RAW
Turbo was free!
If you want a HX35 - S400 (T4) hot pipe PM me. I had a buddy that makes them for me.
https://www.dieselbombers.com/5-9l-2...-hot-pipe.html
Reading through this will answer a few of your questions
Old Jan 19, 2011 | 06:47 PM
Pmd you rawilliams. As for piping I checked out your pics I thought the hx Pushed the air into the s400. That's what I understood at least. Yours has the s400 pushing the hx doesn't it? I may be wrong I'm 17 an just getting into the twin turbo ideas. Thanks for the help guys.
Old Jan 19, 2011 | 07:17 PM
RAW's Avatar
RAW
The "big" turbo, S400, pushes into the "small" turbo. It doesn't work the other way around. The big one always, to my knowledge, feeds the little turbo.
Old Jan 19, 2011 | 07:26 PM
I may want uPgrade from my hx35 then because there prone to explosion after 35 psi suposibly from what I hear. Ill check out our at equip junkyards did I read that yours came off of a John Deere 12.5l tractor?
