tuners? which one for my truck
Old Jan 19, 2011 | 12:15 AM
balesrd513's Avatar
Default tuners? which one for my truck
thinking really hard which tuner i want for my truck, i have a 2010 dodge 2500 cummins which tuner will i get the most power out of and the performance, i know everyone says smarty or black maxx and edge but i want someone to actually tell me some results, any info would help fellas thanks
let me know some different results
Old Jan 19, 2011 | 07:58 AM
CoalTrain99's Avatar
i have an xrt from h&s same programs but its not on the fly and i dont have the fancy little screen, i like the tuner alot plus you can download free hot tunes
Old Jan 19, 2011 | 08:02 AM
bobcat67's Avatar
H&S is the best for the 6.7 in my opinion
Old Jan 19, 2011 | 08:16 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
smarty is not released yet for the 2010. its almost ready. h&s stuff is good for the 2010
Old Jan 19, 2011 | 08:17 AM
Default Re: tuners? which one for my truck
Id check out the Mini Maxx or XRT Pro
Luke
Old Jan 19, 2011 | 08:22 AM
Hummin Cummins's Avatar
There is no smarty available for the 2010. '
I have the H&S and if your planning on leaving the DPF filter in place your wasting your money. With everything removed the H&S does run code free but the power performance is not impressive at all.
I would buy a smarty if it was available.
Old Jan 19, 2011 | 05:43 PM
balesrd513's Avatar
i plan on running a turbo back exhaust, no dpf filter
thanks for the comments guys keep em comin
Last edited by balesrd513; Jan 19, 2011 at 05:43 PM. Reason: Automerged Doublepost
Old Jan 20, 2011 | 07:55 AM
Power Performance is not impressive with the H&S???..i Can break the tires loose on a 30 roll on the middle setting. All i Have is a 5 inch TBE no muff/ with an xrt i was very impressed
Old Jan 20, 2011 | 09:12 AM
I can brake my tires loose on a 30 mph roll if I am on ice. I have to talk to someone at H&S again becase this can't be normal.
Old Jan 20, 2011 | 09:50 AM
barkrulz's Avatar
I have a mini maxx and on mild it is impressive, on wild when i leave a light i have to peddle it a bit or it's just a smoke show. haven't used the highest setting, waiting to get head studs, wastegate and tranny program (maybe new TC).
If your not impressed with the H&S programmers. It's either not working correctly or you're used to way bigger HP than these give as a first mod. 60 hp is roughly a 20% gain over stock and 90 is almost 30%.
I like mine, it's easy and code free (truck thru a code for low voltage, not related to mini, used mini to clear it after fix).
and great fuel mileage
