no start after airdog install
Old Jan 18, 2011 | 09:43 PM
eloydiesel's Avatar
Default no start after airdog install
working on 2005 dodge cummins. had a hard start problem so i installed new injectors and a air dog. now im am not getting any fuel pressrue from injector pump and air dog is giving it 17psi. any ideas
Old Jan 18, 2011 | 10:18 PM
Did you bleed the air out?
Old Jan 19, 2011 | 11:15 AM
12vcummins96's Avatar
any codes
Old Jan 19, 2011 | 11:32 AM
Farmboy 2.0's Avatar
Did you fill the filters up? And did you pull the fitting off the cp3 to see if fuel is coming out
Old Jan 20, 2011 | 06:52 PM
eloydiesel's Avatar
yes i have done all of that. i am not getting any fuel from cp3 now
Old Jan 20, 2011 | 07:11 PM
crzycummins's Avatar
have you checked to see if you have any bad fuses or relays. maybe a bad connection to the cp3
Old Jan 20, 2011 | 07:17 PM
Whit's Avatar
Site Mascot
I had this issue once with a Fass.............same only different
turns out the Fass was vaporlocked, I pulled the discharge off the pump and it took off hell bent for leather
Old Jan 21, 2011 | 11:24 AM
eloydiesel's Avatar
yes i have checked all fuses all connections even changed out cp3 with known good one
Old Jan 21, 2011 | 01:49 PM
do these have a regulator that might be stuck?
Old Jan 21, 2011 | 02:04 PM
HAve you seen if there is fuel at the filters and if fuel is pumping out? Any pinched lines going to pump?
