fuel economy
Old Jan 18, 2011 | 11:44 AM
01_cummins's Avatar
Default fuel economy
i have an 01 24v H.O. cummins with bigger turbo bullydog outlook 5 inch turbo back exhuast and 6 spd manual tranny. it has a 6 inch suspension lift with 37 inch tires and stock gears. its a long bed quadcab and im trying to get better fuel economy without paying a whole lot of money you know? i have been thinking bout dropping the gears a bit and it needs a clutch. is there any ideas? id realy apreciate the ideas thanks guys!
Old Jan 18, 2011 | 12:07 PM
Farmboy 2.0's Avatar
Do you have Injectors? If not a set of RV injectors will help you squeak alittle bit more out of it.
Old Jan 18, 2011 | 02:51 PM
01_cummins's Avatar
arent injectors expensive to put in though?
Old Jan 18, 2011 | 03:28 PM
A set of 75hp injectors and a Edge EZ.
Old Jan 18, 2011 | 05:43 PM
No they a set of RV 275 would be a few hundred bucks and you can do it yourself in a about 2 hours or so
Old Jan 18, 2011 | 06:32 PM
01quadcab's Avatar
smaller tires, less skinny pedal and like luke said and ez
Old Jan 19, 2011 | 12:55 PM
01_cummins's Avatar
the tires i run are very cheap so i am trying to avoid downsizing tires. what rpm do ya'll run ur trucks at? and whats the HP rating on the RV275's? thanks
Old Jan 19, 2011 | 05:43 PM
chadcycle 2500's Avatar
what are your stock gears?
I'm running 4.10s Lt 265 75-16 tires around 2000 rpms,@ 55 MPH 20 mpg on hiway,EZ on the skinny pedal
Last edited by chadcycle 2500; Jan 19, 2011 at 05:43 PM. Reason: Automerged Doublepost
Old Feb 2, 2011 | 09:35 PM
blue24valvecummins's Avatar
i went from the factory 245-75-16's up to a 285-75-16 and noticed a hair better milage it dropped my rpm at 70mph
Old Feb 7, 2011 | 11:58 AM
01_cummins's Avatar
i turn around 1800 at 75 mph down the black top but i do not have an acurate odometer or speedometer. i rely on my programer to tell me my speed. anybody know were i could get the different gears in the speedometer cable on the transmission end so that my odemeter and speedo would be accurate? thanks for the help
