Possible injector problem?
Old Jan 18, 2011 | 01:32 AM
jkeats22's Avatar
Default Possible injector problem?
So when I have my truck idling, about every 15-30 seconds my truck will have like a burp. It seems like it is idling normal, then it will die down for a quick second then idle normal..... Also I think its my injectors cause it doesnt seem like I am getting as much power as I should be! How much would new injectors be (like the 90hp) and how hard is the install? Someone please help me! My truck has 82,000 miles, and I wan more hp so I was thinking about replacing the injectors anyways!
Old Jan 18, 2011 | 12:04 PM
SANDERS's Avatar
Default sanders
dealer wants $650.00 ea. find them on web for $350.00 cant tell if they are good or not
Old Jan 31, 2011 | 05:37 PM
TeckJohn's Avatar
Try tightening your injector tubes. They are alot cheaper than injectors and then if it doesnt run better spend 200 on a scanner and find out which injector is bad and then replace it. It is not hard. I can tell you how and show you pics
Old Jan 31, 2011 | 07:23 PM
Timecode's Avatar
Default Re: Possible injector problem?
My truck does the same thing. Very noticeable when in a drive thru. My truck seems to run fine otherwise. I have 90hp injector nozzles waiting to put them in.
Interested to know what you find out.
Sent from my DROIDX using Tapatalk
