2nd Gen Stock Tire Pressures
Old Nov 24, 2007 | 12:48 AM
DB Admin's Avatar
Banned
Default 2nd Gen Stock Tire Pressures
Old Nov 24, 2007 | 09:31 AM
Nitelord's Avatar
Would running full pressure all the time, cause the tires to wear - strangely?
I run full pressure all the time and the fronts seem to scallop quickly. Maybe it's just the Hankooks...
Old Nov 24, 2007 | 09:55 AM
Wyatt Earp's Avatar
I too run full pressure but pressures listed on the rubber not the truck. For me and my 285 yoko's it is 65 front and 70 rear - loaded or unloaded all year. I rotate every 10,000 km and have no wearing issues except age / distance related.
Old Nov 24, 2007 | 03:17 PM
EMD567's Avatar
Running full pressure would make the centers of the tires wear before the outer parts of the tread, and running less would make the outer parts wear before the center area. Depends on what you pull with your truck. I usually run about 55-60 in load range E tires, and 50-55 in D's. Just make sure to check the sidewalls first.
Also, don't forget to rotate. I don't think you can rotate tires too much. I do every 5-8k for all terrain/all season tires. Remember you put your chopped up front tire on the back, and it should straighten right out.
Jsully
Aug 31, 2015 07:55 PM
dieseldriver626
Aug 22, 2015 08:33 PM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
myago92
Oct 17, 2014 08:50 AM
