Boost? Hissing
Old Jan 17, 2011 | 04:29 PM
moneyman_09's Avatar
Default Boost? Hissing
Ok so this morning i got in the truck started down the highway got onto it to get around this slow car and noticed a hissing noise from under the hood at first i thought it was a boost line to my gauge i checked it and it's all fine next i thought maybe the wastegate had iced up or suck open messed with the accuator and everything seams fine what else would make it hiss at high boost.
Old Jan 17, 2011 | 04:42 PM
Farmboy 2.0's Avatar
Hole in intercooler boot? Or a silicone boot on the twin piping
Old Jan 17, 2011 | 04:47 PM
Thanks i'll have to check them if it was above 15 outside i would have already had them tore down and checked. egt still stay the same still has same power so must just be a small hole.
Old Jan 17, 2011 | 05:08 PM
Yep get some soapy water in a spray bottle and spray the boots. It if bubbles you have a hole
Old Jan 18, 2011 | 09:52 PM
So i checked the boots today and could not find any bubbles.
Old Jan 18, 2011 | 09:58 PM
heavy hauler's Avatar
Have somebody ride under the hood while you are going down the road and see if they can see any bubbles then. Just kidding. the hole in the boot will not be that big. Probably just a pin hole. Check anywhere that could rub. also check the intake horn gasket on top and bottom of the grid heater.
Old Jan 18, 2011 | 10:00 PM
Thanks i can hear the sound is on the passenger side just cant pinpoint it i think i might just replace the boots and see if that helps.
Thanks
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
joshkhouse80
Nov 21, 2014 01:17 AM
