Truck Won't Start
Old Jan 17, 2011 | 01:48 PM
3500dodge's Avatar
Default Truck Won't Start
I have a 03 CTD that will not start hot or cold. The only way it will start is with a little starting fluid which I know is bad but needed to drive. The truck runs great once it is started but will not restart when shut-off. It also keeps blowing the Fuel Heater Fuse like I have a short somewhere or something. Any ideas????
Old Jan 18, 2011 | 03:21 PM
redruM's Avatar
sounds like injector or fuel pump problem
Old Jan 21, 2011 | 05:17 PM
wide open's Avatar
i would say injectors because my o3 was the same no start hot or cold .used starting fluid and it ran good when i got it started it had 3 bad injectors
Old Jan 21, 2011 | 10:00 PM
camo cummins's Avatar
Default 03 wont start
i have an 03 single wheel 1 ton that wouldnt start changed pump in tank with no luck took it to dealership come to find out there wee 2 wires in my ecm that were frayed they fixed those and those two wires were also overloading my starter so i replaced that to and it starts better than it ever has i hope this helps.
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
