HX50 turbo
Old Jan 17, 2011 | 01:12 PM
WaitinOnaCummins's Avatar
Default HX50 turbo
Alright guys i found a new hx50 turbo that i was thinking of replaceing the old hx35 with. But i was thinking it would be a lot of turbo to spool, but im new to the diesel world. So i would like to hear you opinions on it. Thanks guys
Old Jan 17, 2011 | 06:02 PM
Hightech_Redneck's Avatar
do you know what the exhaust housing size is ?
you will need to have a set of injectors, a tuned pump, a transmission.... its a decent turbo
Old Jan 17, 2011 | 08:17 PM
No i sure dont, but ill find out. This thing is like brand spankin new. It hasnt evan been installed on any thing yet.
Im planning on getting a new tranny and injectors here pretty quik so we are good there
Old Jan 17, 2011 | 08:46 PM
12valvetater's Avatar
Make sure you get inducer and exducer of both wheels.
Old Jan 26, 2011 | 08:41 PM
RUSS83's Avatar
CAN I PUT A TURBO OFF A SEMI ON MY TRUCK WITH 435 INJUSTORS AND WILL IT SPOOL UP JUST BUILDING A PULLING TRUCK
Old Jan 26, 2011 | 08:56 PM
turbostang7's Avatar
WHY ARE YOU YELLING? gonna have to be a little more specific on the semi truck turbo, many out there available so we are gonna have to have something to go on for ya and if its a pulling truck only then a big single is ok, but if it sees any street time, forget about it, gonna be a dog and extra toasty on the egt's
Old Jan 27, 2011 | 12:17 PM
ideal is a 16cm housing or smaller for a single... im running a 72mm on my truck with supporting mods... hoping its not going to be too laggy
Old Jan 27, 2011 | 10:28 PM
RUSS83's Avatar
ANY TURBO OFF A SEMI I CAN GET WHAT EVER TURBO I WONT CHEAP OFF A SEMI
Old Jan 27, 2011 | 10:35 PM
some off of semi trucks will work fine, others will not work at all, i have heard that the cat c7 has a s300 turbo off of it, that would work pretty good on our trucks, the best thing to do is do some research about what you have available and ask around to see whats going to work best for ya! you could also just use your hx35 you have and put an ht3b under it for twins! that works great. oh and just a heads up on the internet if its all caps it means you are yelling
Old Jan 28, 2011 | 08:09 PM
RUSS83's Avatar
OK THANKS and i will stop yelling
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
