Dodge Diesel Tech Articles All Years of Cummins Tech Talk
MAP Sensor Voltage Data
Old Nov 24, 2007 | 12:16 AM
DB Admin's Avatar
Banned
Default MAP Sensor Voltage Data
These are the voltage readings a properly function MAP sensor should show.
Boost - Voltage
0 - 1.045
6 - 1.48
10 - 1.75
15 - 2.05
18 - 2.27
20.5 - 2.44
Old Dec 6, 2007 | 11:05 PM
Lostnwalmart's Avatar
what if u go over 40 psi.....? 4.88 v?
Old Dec 7, 2007 | 05:41 AM
DB Admin's Avatar
Banned
Sounds Rational to me
Old Dec 7, 2007 | 08:33 AM
Benjamin's Avatar
Bombardier
i would assume 3.82 since that's the pattern that i'm finding..... remember that you can't double the 20psi voltage as you started off at 0psi at 1.045v.... what i did was subtract the 10psi voltage from the 20psi voltage and that number range is good for approx. a 10 psi difference. so double that and add it to the 20 psi and you get the 3.82ish and that "should" be 40psi or so.....
Old Dec 7, 2007 | 04:35 PM
Fishin2Deep4U's Avatar
I have the data somewhere. The factory MAP will measure all the way up to close to 60PSI.
Dave
May 1, 2015 08:10 AM
Jan 9, 2015 09:30 AM
IslanderXJ
Dec 17, 2014 04:14 PM
Dec 3, 2014 08:10 AM
Spiderman
Oct 6, 2014 04:37 PM
