H&S Blackmaxx question
Old Jan 16, 2011 | 11:33 PM
93/250's Avatar
Default H&S Blackmaxx question
Ever since i put my blackmaxx in, my radio reception went right to crap. At first i thought it was in my head but if i shut the truck off and continue to listen to the radio as soon as the blackmaxx screen shuts off, the radio is crystal clear. It is installed exactly as H&S says. Anyone have the same problem? Absolutely love everything else about the blackmaxx.
Old Jan 16, 2011 | 11:34 PM
Rustin's Avatar
Stock stereo receiver?
Old Jan 17, 2011 | 06:21 PM
93/250's Avatar
Yes, stock 6 disc cd changer. Forgot to add that
Old Jan 17, 2011 | 08:34 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have not heard that before. call h&s and see if they can fig what is going on. im sure they would like to know.
Old Jan 17, 2011 | 09:20 PM
kmkdiesel's Avatar
Were is your power wire ran, and how did you run it there, it could be a posibility that wire is to close to another wire causing interference, i have seen it with cb radios but not really a stock stereo, you maybe could try putting the plastic wireloom over the powerwire to see if that helps.
Old Feb 2, 2011 | 06:36 PM
PSDNUTS's Avatar
why don u disconnect the power wire and use the switch on OBDII port and see if it makes any difference . than u know if its the unit or the power wire,
hope this helps
Old Feb 3, 2011 | 08:56 PM
kmkdiesel's Avatar
hope this helps
Not all of them came with the switch on the obdII plug, but I think all of the newer ones do now.
Old Feb 4, 2011 | 04:09 AM
PSDNUTS's Avatar
i didnt know that,
in this case he can try different places to get 12v and see if its still the same, than talk to H&S
Old Feb 6, 2011 | 02:19 AM
barkrulz's Avatar
Did you tap the stero wire off the ignition? I ran a hot to the recommended junction in the fuse block, and keep my switch in the position where it is only on with the key. My stereo is an aftermarket kenwood cd/dvd/satalite unit. no noise, nothing. Check and make sure you tapped the right fuse.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
