6.5 Diesel Power Mods=Realiability Sacrifice???
Old Jan 15, 2011 | 06:53 PM
palmer6.5td's Avatar
Question 6.5 Diesel Power Mods=Realiability Sacrifice???
Finally going to invest in some more power. Anybody have any advice for a person trying to hop up a stock 96 6.5??? Looking at a Heath GL4 and Bosch HO injectors....
Old Jan 15, 2011 | 09:46 PM
Crazy's Avatar
well it good start before put all that in my truck i be put gauges in first and for i don't what you mean buy HO borsch injectors if you are talking about Marine Injector don't waste your money on them cause IP only put out some PSI and not going do sh|t for you but do want run reg borsch injector they are the best i would have them pop test first before install on 96 i would fine air box and filter for 97
Old Jan 15, 2011 | 10:20 PM
Well the injectors are Bill Heath's modified output Bosch injectors, if hat means anything... I'm installing a triple gauge kit next week with egt's, boost and fuel pressure. I am currently running SSD's S+B intake. Truck has 235,000 kilometers.
Old Jan 15, 2011 | 10:52 PM
Crazy's Avatar
well it sound like you taking right steps link me the injector you are planing to run cause you buy borsch injectors from rockauto cheaper
Old Jan 15, 2011 | 11:07 PM
They're on Heaths website...
BOSCH High-Output fuel injector set 1992-2000 GM 6.5 Turbo
Old Jan 15, 2011 | 11:18 PM
Crazy's Avatar
not to knock heath down he his good guy but that first that i have here of bosch HO injectors now bosch injectors are good i got mine from rockauto for 40.00 pc x 8 = 320.00 compaired to 759.oo maybe someone can charm in on this
Old Jan 15, 2011 | 11:22 PM
DSG in Saskatoon sells the 40 horse marine injectors that everyone says just make a bunch of smoke and burn fuel. If I get his computer, I want to seal the deal with the injectors that are made for it. But it will work with either standard or high output.
Old Jan 16, 2011 | 10:52 AM
Crazy's Avatar
i go with standard if it was me to me 40hp injector not going gave you more fuel the IP is only going put out so much PSI in fuel and not going gave you more so to me just wasting money marine injectors
marine injector can hurt your IP cause of the higher pop pressure
Old Jan 17, 2011 | 01:56 PM
Woody35's Avatar
you need a hotter tune than an GL4 to take advantage of marine nozzles. put in the regular ones and you will be happy and will have more money in hand
Old Jan 17, 2011 | 05:46 PM
Mapleleafpete's Avatar
What about rebild kits for injectors ? on my 6.2 yrs ago a buddy tested them and the spray was all over the place so he rebuilt mine.After we tested them and they poped at the right pressure(cant remember the exact psi) and had a nice even mist.Do they sell rebuild kits to up pressure and fuel delivery ?
