sdx injector washers
Old Jan 15, 2011 | 10:17 AM
line worker's Avatar
Default sdx injector washers
hey guys quick ? i just got my injectors out and im about to put my 7 hole sdx injectors in but dont know what washers to use and cant get ahold of anyone at sdx. need help quick
Old Jan 15, 2011 | 03:53 PM
94 12valve's Avatar
did they give you washers with the injector? if not use the washer that is the same thickness that came out of the motor, or a thinner washer.
Old Jan 15, 2011 | 06:01 PM
they sent 3 sets. i used the thinnest ones. that put it closest to stock since the tips were a different length
Old Jan 15, 2011 | 07:04 PM
94 12valve's Avatar
did they tell you the cone angle of the 7 holes?
Old Jan 17, 2011 | 08:19 AM
145*
Old Jan 17, 2011 | 08:36 AM
Red_Rattler's Avatar
High Tech Redneck
Closest to stock is where u wanna be. You did it right.
Old Jan 17, 2011 | 09:11 AM
i put my 100 pate as far forward as the housing would let it go and the housing as far forward as the slotted holes would let it and i have no smoke at all. it dosnt feel like it has the power it should w the injectors and plate. when i turned the starwheel toward the engine it lost power what am i doing wrong
