Turn signals
Old Jan 15, 2011 | 12:01 AM
dragrcr's Avatar
Default Turn signals
I have a 01 with welding bed. I put LED lights on it & the turn signals blink really fast. Is there a fix for this. I don't think it will hurt anything it's just aggravating were they blink so fast. Any suggestions would be appreciated.
Old Jan 15, 2011 | 12:27 AM
kingbrad89's Avatar
One of 2 things. Inline capacitors with the wiring to add resistance is the first. LEDs use much less power so it blinks fast just like as if a bulb were burned out. 2nd thing to try, and much easier, replace your front turn signals with led replacement bulbs. It slows em down most of the time when you do that also.
Old Jan 15, 2011 | 11:18 PM
dragrcr's Avatar
Do you know were I get LED bulbs.
Old Jan 16, 2011 | 09:17 AM
RAW's Avatar
RAW
There are signal light flashers designed for LED's to cure the fast flashing. Some auto parts stores should carry them.
LED bulbs can be bought online, both Recon and superbrightleds.com carry them.
Old Jan 16, 2011 | 04:21 PM
kingbrad89's Avatar
I would stop at autozone and grab a set of amber led bulbs and put em in the front. Easiest way to fix it
Old Jan 16, 2011 | 05:32 PM
H.R.D's Avatar
Putting in more LEDs is not going to fix this problem trust me I went through it already. You have to find a LED 5pin Flasher relay. I found mine on ebay and they work great. They support up to 6 bulbs which means you can put a trailer on with no problems. I have searched on ebay for the one I bought but nothing comes up. I will keep an eye out if I found one I will post it in here.
Here you go this should work for you.:
LED turn signal auto truck hazard 5 Pin Flasher - eBay (item 360335462054 end time Jan-18-11 11:21:50 PST)
Old Jan 16, 2011 | 06:25 PM
dragrcr's Avatar
can't thank you guys enough. this is why i use this forum. i will try the electronic flasher. thanks again
Old Jan 16, 2011 | 10:08 PM
kingbrad89's Avatar
That looks like it'll work. And I have most definitely had success in the past putting LEDs on the front and back and having them flash correctly.
Old Jan 16, 2011 | 10:48 PM
H.R.D's Avatar
Logical it doesn't make since. LEDs use less voltage and wattage to work. This makes the flasher think there is no lights. I had my tails in with the fast blink for a long time then I put front leds in and they didn't work at all. However if it worked for you then I can't really argue against that.
Old Jan 17, 2011 | 02:56 PM
kingbrad89's Avatar
I'm going to guess it differs from vehicle to vehicle. If you take both the front and rear bulbs out of a car, it will blink on the dash at the normal speed. So if the wattage is low enough, it may work for that reason. I had an 01 blazer that this worked in. Haven't tried it in these trucks yet
Mac1997
Jul 13, 2015 05:08 AM
klein444
Jun 20, 2015 11:48 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
willgoss
Ford Powerstroke 08-10 6.4L
Feb 12, 2015 09:52 PM
Nov 16, 2014 06:10 PM
