IP timing -1.94
Old Jan 14, 2011 | 11:50 AM
Whit's Avatar
Site Mascot
Default IP timing -1.94
I would sure like to learn more about this timing that member Crazy has in his sig
1997 3500 Ext Cab 2 Wheel Drive 300,000 plus miles
New Trans with up grades for towing Rebuild Rear end 4:11 with
new axles,newjectors, 4" Exhaust , 5" tip, PMD Moved to front
bumper,IP time to -1.94,new LP,boost,EGT and trans gauges and
pull a 38ft 5th wheel with 3 slide wgt 16,500lbs
Old Jan 14, 2011 | 11:58 AM
Crazy's Avatar
it turning pump to the right for max power with out setting SEL off it retarding pump
Old Jan 14, 2011 | 12:05 PM
Whit's Avatar
Site Mascot
I understand that part, its just different than a 12 valve cummins by a long ways
can you give us detail on how to get to the -1.94 and what all it takes
Old Jan 14, 2011 | 10:24 PM
Crazy's Avatar
just have my buddy part on his tech2 scanner he did the timing he set all up for me lost 1/2 mpg though but get more power and great when towing i know cummins total diff from chevy could tell you if do anything for that pump on not
should also i gain about 3 or 4 hp not all that much but take what can get
Correction not retarding
advances the timing basically tells the computer where the best spot to inject is better mileage, throttle response and make engine a bit louder but i didn't see better mileage
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
