Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Snow Performance
Old Nov 22, 2007 | 09:02 PM
FormerVendor
Default Snow Performance
Anyone interested in a Awsome price on a Snow Performance Stage 1, 2, or 3 Water Meth System??
All Makes and Models are Welcome!!!
I WILL NOT be undersold
Old Nov 22, 2007 | 09:10 PM
mysterync's Avatar
Of course unless i undersell ya
Just Kidding
Old Nov 23, 2007 | 12:07 PM
FormerVendor
Old Nov 24, 2007 | 12:34 AM
SkeetSkeet's Avatar
sure a price wont hurt stage 3
Old Nov 24, 2007 | 06:38 AM
FormerVendor
Old Nov 25, 2007 | 04:01 PM
FormerVendor
Old Nov 25, 2007 | 06:07 PM
bway1341's Avatar
What is the difference in stages and price per stage.
Old Nov 25, 2007 | 06:18 PM
06 DIESEL's Avatar
I also do not know the difference, please let me know, I might be interested depending on price and cash flow.
Old Nov 25, 2007 | 07:31 PM
FormerVendor
Stage 1:
Stage 1 Diesel Boost Cooler
This kit progressively injects more or less water-methanol, according to manifold boost pressure. The system is applicable for turbo diesels making up to 25psi of boost pressure. It has two dials to set the start and full points to tailor the delivery to your engines needs. Progressively injecting according to boost pressure allows for the most power over the widest range of rpms. Now with Lifetime Warranty
Kit includes:
• 150+ PSI High Volume Pump
• 2 Quart Reservoir
• Bulkhead Fitting
• Digital Variable Controller
• 2 Nozzles To Cover a Wide Range of Horsepower
• All Required Hardware Needed For Installation
• Comprehensive Instructions
$454.93 MAP Price
Stage 2
Stage 2 Diesel Boost Cooler
These kits work on exactly the same principle as the Stage 1 kits, except that the controllers are heavier duty and can read up to 100psi of turbo boost. This is the typical starting point for a mildly modified modern 3/4 or 1 ton truck with an aftermarket exhaust, intake and chip or programmer. It is capable enough for trucks running large or compound turbo systems as well. These kits allow for great horsepower increases and EGT reductions – expect about 70hp and 250 degree F EGT drop. Now with Lifetime Warranty
Kit includes:
• 2 Quart Reservoir
• Bulkhead Fitting
• 3 Nozzles To Cover a Wide Range of Horsepower
$551.93 MAP Price
Stage 3
The Stage 3 Diesel Boost Coolers are the most comprehensive water-methanol injection kits Snow Performance makes. This controller senses not only manifold boost pressure but also exhaust gas temperatures. Using two inputs allows for the smoothest injection control. More importantly, it also keeps the EGTs as low as possible – if they begin to climb, even if the boost stays constant, the Stage 3 controller will read this and inject more water-methanol to compensate. The adjustments to the delivery on the fly are accomplished with two easy-to-use push buttons, allowing for more or less injection, or switching from both boost & EGT referenced injection (smoothest, best for towing and EGT control) to just boost referenced injection (most responsive, best for performance and racing). Now with Lifetime Warranty
Kit includes:
• 2 Quart Reservoir
• Bulkhead Fitting
$745.93 MAP Price
Remember I can only post MAP prices
Last edited by Diesel Dawgs Performance; Nov 25, 2007 at 07:31 PM. Reason: Automerged Doublepost
Old Nov 25, 2007 | 07:34 PM
Begle1's Avatar
When's Snow coming out with competition to the Cooling Mist DMS?
Cooling Mist still doesn't have software that allows multi-variable control for the continuous output...
