06 3500 Problem
Old Jan 13, 2011 | 04:59 PM
CHEMMINS's Avatar
Default 06 3500 Problem
I have a 2007 3500 5.9 (disregard the title of the thread, my old truck was an 06) and my abs and brake light are on.
Put it in 4hi on the fly, and the light just blinks.
Stop the truck in neutral and put it into 4low, everything goes normal and the truck engages into low.
Move the switch to 4hi and the truck engaged.
So right now the 4hi will not engage or disengage unless I put it into 4low first.
Also when driving, the speedo will drop to 0 for 10 seconds or so, then go back to normal.
Don't have a code reader either......but thought someone here may have had this happen to them.
Old Jan 13, 2011 | 05:42 PM
haulitrite's Avatar
Mine acts kind of like that only when it is real cold like -10 degrees F or lower
I have a 6sp so I don't know if that makes engaging it different.
Old Jan 13, 2011 | 07:04 PM
CHEMMINS's Avatar
Hmmm.....don't know if the cold has much to do with it. I only have had to use it since it snowed. Mine is an auto.
Old Jan 18, 2011 | 02:59 PM
CHEMMINS's Avatar
No one else huh?
Old Jan 26, 2011 | 03:35 AM
Sirwrenchiezolot's Avatar
Maby it has something to do with a wheel speed sensor being out since ur abs light is on and it wont shift because it doesnt have a reading on speed but im really not sure if that matters or not because i have no idea what parameters it requires to make it shift but its a avenue to check out good luck
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Jun 22, 2015 12:40 PM
swartile
May 8, 2015 01:03 PM
thurobred1320
May 5, 2015 09:26 PM
