Drive Shaft ?
Old Jan 13, 2011 | 07:57 AM
hxjetski's Avatar
Default Drive Shaft ?
Was pulling my Parasail Boat over the weekend and started to get a vibration from the drive shaft, after looking the center bearing is shot. What I need to know is how do I get the carrier of the drive shaft, is it something I can do or do I have to take the drive shaft to a shop???????
Thanks guys
Old Jan 13, 2011 | 08:54 AM
DieselCrawler's Avatar
it is pressed on. not to bad of a job. get a new bearing, cut the old one off(torch, cutoff wheel) and clean up the shaft where the bearing slides on. then find a peice of pipe the size of the bearing and tap it on.
unless u have acces to a press.
Old Jan 15, 2011 | 01:54 AM
Sycostang67's Avatar
I couldn't for the life of me get mine off. After much frustration I just took it in and had all the joints and the carrier replaced as well as getting it balanced that way I wouldn't have to worry about anything on the driveshaft for a long time.
Excursion73
Sep 12, 2015 10:52 AM
morris360
Aug 5, 2015 09:25 AM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
